RL_TCP CRASHES
Dear All
I have created 3 tasks,
this is task one it has a osPriorityBelowNormal
        for(;;)
                main_TcpNet ();
This is task 2 it has a osPriorityHigh
        for(;;)
                /* Timer tick every 100 ms */
                timer_tick ();
                osDelay(100);
this is the task 3 it has osPriorityNormal
        U8 Rem_IP[4] = {192,168,0,1};//The PC IP
        uint8_t *sendbuf;
        tcp_soc = tcp_get_socket (TCP_TYPE_CLIENT_SERVER | TCP_TYPE_KEEP_ALIVE, 0, 30, tcp_callback);
        tcp_listen (tcp_soc, 1943);
        for(;;)
                osDelay(1000);
                switch (tcp_get_state (tcp_soc);)
                 case TCP_STATE_FREE:
                 case TCP_STATE_CLOSED:
                 case TCP_STATE_LISTEN:
                        tcp_connect (tcp_soc, Rem_IP, 2121, 0);
                 break;
                case TCP_STATE_CONNECT:
                  if (tcp_check_send (tcp_soc) == __TRUE)
                   sendbuf = tcp_get_buf(1460);
                   //Fill buffer in here
                  tcp_send (tcp_soc, sendbuf, 1460);
                 break;
But when the application runs for some time it will crash and it would tell that
/* Locked Memory management function (alloc/free) re-entered. */ /* RTX multithread protection malfunctioning, not implemented */ /* or interrupt disable is not functioning correctly. */
What's wrong? do you have any idea?
