howto: function library in separated hex-file
Due to the lack of flash memory i want to move code parts in a separate function library and locate the same in RAM. I thought to use the LIB166 and assign certain code modules to the RAM-address area.
In addition i want be able to build and deploy (download) this RAM function library without the need to build&programm the flashed code again. Means i need the hex-files: flashcode.h86 and functionlib.h86.
Is there a way to create a functionlib.h86 with the LIB166 and L166 which shares certain interface functions to a flashcode.h86? Or are there any alternative solutions?
