How to transfer usb microphone streaming data at 44.1kHz
Hi all,
I am implementing a stereo, 16bit-res microphone application. The application should send the recorded data over USB to PC.
I succeeded to make the microphone work well at 48kHz and now I am stuck at isochronous transfer at 44.1kHz.
The isochronous transfer type is Synchronous. And the In endpoint max packet size is 192bytes.
I use the 'usblyzer' to grab the packets that I found 3 different results:
(1) When I send 176 bytes data to PC every millisecond. PC can received 1760bytes/10ms.
(2) When I send 180 bytes data to PC every millisecond. PC can received a random amount of data between 500 to 800.
(3) When I send 9 x 176 bytes and one 180 bytes every 10 millisecond. PC can received 1412bytes/10ms or 1760bytes/10ms(4x1412 and 1x1760 as a period).
So I guess I made a mistake at how to transfer the streaming data at 44.1kHz over usb to pc.
Can anybody tell me how to transfer streaming data at 44.1kHz over usb to PC?
  • > (3) When I send 9 x 176 bytes and one 180 bytes every 10 millisecond.
    This could be the right way,
    if you would write it as "10 frames", instead of "10 milliseconds".
    1 frame is not exactly 1 ms. It’s 1ms +/- 500ns, determined by the host.
    In Synchronous method, your local sampling clock has to synchronize to SOF timing.
    I recommend you [b]A[/b]synchronous instead of Synchronous, for easy microphone implementation.
    In Asynchronous method, your local sampling clock is the master clock.
    The number of samples in a packet is determined by the number of samples in the last SOF interval. And then, you don’t need to worry about either 44.1 or 48 kHz.
    Tsuneo
    Tsuneo
