Problem in migration from SAM3S8B to SAM3S(2/4)A
Hi all,
I have this funny yet annoying issue.
I was developing a USB hardware, with composite device function (HID+MSD), containing cryptographic algorithm implemented in assembly and a lot of logical code in C in the firmware.
I was using SAM3S8B and everything was good.
Now is the time for bulk production of this hardware, But I noticed if I reduce the RAM usage to under 32k I may use SAM3S2A with a considerable cheaper price and I did it.
The problem is:
The firmware works fine in my own debug board using SAM3S8B but when testing it on a SAM3S2A or 4A, it randomly causes hard fault exception.
The code size is
CODE = 82512
RO = 4596
RW = 300
ZI = 28580 (4k stack size included while estimated stack size = 3k)
The debug boards are the same which can contain both 48 pin and 64 pin SAM3S micro controller.
The funny part still remains:
I had 2 static libraries in my project using SAM3S8b configuration in their own projects, which I fully changed them as well as the main project configuration and SYSTEM and STARTUP files to SAM3S2A.
The annoying point is whether I change these configuration or not the result is the same:
It works fine in a board with SAM3S8B even using SAM3S2A configuration, but none of the configurations work for SAM3S2A or 4A.
is there anything I'm missing here?
may someone help me?
uVision version = 4.70.0.0
debugger used = keil ulink2
