It must be a novice question but I have been trying for days without success. I created RTX First project example using PDF guide but when I built the project and started the simulation it didn't even get to init task. Then I built the already finished project in Full project folder and started the simulation. This one worked fine.
I soon realized that built projects have different code sizes. Full project is 6020 bytes and RTX First project is 5468 bytes in size. Their first part is different. <RTX First project> starts like this:
0x00000000 E59FD00C LDR R13,[PC,#0x000C] _main_scatterload: 0x00000004 EB00029F BL $Ven$AT$I$$__scatterload(0x00000A88) __main_after_scatterload: 0x00000008 E59F0000 LDR R0,[PC] 0x0000000C E12FFF10 BX R0 0x00000010 00000528 ANDEQ R0,R0,R8,LSR #10 __rt_final_cpp: 0x00000014 40000D38 ANDMI R0,R0,R8,LSR R13 .....
And Full project starts like this:
0x00000000 E59FF018 LDR PC,[PC,#0x0018] 605: LDR PC, Undef_Addr 0x00000004 E59FF018 LDR PC,[PC,#0x0018] 606: LDR PC, SWI_Addr 0x00000008 E59FF018 LDR PC,[PC,#0x0018] 607: LDR PC, PAbt_Addr 0x0000000C E59FF018 LDR PC,[PC,#0x0018] 608: LDR PC, DAbt_Addr 0x00000010 E59FF018 LDR PC,[PC,#0x0018] 609: NOP ; Reserved Vector 610: ; LDR PC, IRQ_Addr 0x00000014 E1A00000 NOP
Looks like the project created using PDF guide is missing first part of the code. I tried multiple timer from the start. Step by step using PDF guide and same problem happens each time so please help.
I am using uVision V4.73.00 on Win7 Professional.
Problem solved. There is a tickbox in 'Options for target' -> 'Linker' tab. it says: 'Use memory layout from target dialog' and it has to be checked.
I am still wondering what is going on. Could anybody please rebuild this project and report if similar problems occur?
I don't care about RTX First project itself. But I have exactly the same problem with my degree project (missing first part of the program code). I absolutely have to solve it but I ran out of ideas how so please help.
Thank you!
Here is example pack that I downloaded: http://www.keil.com/download/docs/403.asp
The project that is causing me problems can be found in RL-RTX -> RTX First project folder. PDF guide is also inside this folder and it takes just couple of steps to make it work. Unfortunately not me.
The already finished version of the same project can be fount in RL-RTX -> RTX First project -> Full project.
Could you provide a link to the PDF you mention?
You look to be missing a startup.s (chiparch.s) assembler source file with the initial vectors and start up code.
