a white space in the argument string of fopen
This may not be a big doubt or querry but kindly have patience.
I m using fopen with nand flash memory.
when is perform
FILE* file;
char filepath[PROTO_FILEPATH_SIZE];
file = fopen(filename, "w");         //filename = "Docs\CBE renamed.txt"
fopen creates a file with the name 'CBD renamed' in the folder Docs (no .txt extension). for any other filename without space characters, file is created with the extension '.txt'
kindly advise
