hello there , i am using arm 7 lpc2148 board ..and when i try to install the hex file from keil ..the board is not responding bt the test hex file for LED blinking they have given is working and i checked my code it has no issue with code bt still it is not working
Yet it still sounds like an issue with your code, or project, fix that and it will probably work...
