TCPnet Error Codes
I posted earlier and got no response and just wanted to follow up once more.
I have RL-ARM TCPnet setup on a device and it only connects and sends and email via the SMTP functions about 50% of the time; all other times it comes back with SMTP_EVT_TIMEOUT or SMTP_EVT_ERROR as shown here: http://www.keil.com/support/man/docs/rlarm/rlarm_smtp_connect.htm
Unfortunately the descriptions of what those error mean is very lacking: in terms of what caused any possible timeout or protocol error.
The following page has a link for error functions but the link actually just takes you to the Ethernet functions page. http://www.keil.com/support/man/docs/rlarm/rlarm_tn_func_ref.htm
I have run Wireshark but the switch I'm using doesn't support port mirroring so I have no way to see the actual data entering and leaving the device and onto the network. I can however see the DHCP request, offer, ack etc.
If anyone has used the TCPnet libraries before and has had any experience with the SMTP functionality, any help is appreciated.
  • There are several reasons that might be causing your problem. Try a debug library and capture the messages. Start with full SMTP debug, and post the log here.
    You can not use an ethernet switch, if you want to track the traffic with Wireshark. However old LAN hubs might be used for that, as hubs are not smart and forward LAN packets to all ethernet ports.
