I'm looking for a way to get the current program counter.
I adapted the function __get_PSP() from core_cmFunc.h in the following way:
__STATIC_INLINE uint32_t __get_PC(void) { register uint32_t __regPC __ASM("pc"); return(__regPC); }
this compiles fine but it results in the following code:
;;;278 RES_RestartPC(0x10, __get_PC()); 000022 bf00 NOP 000024 bf00 NOP 000026 4683 MOV r11,r0 000028 4659 MOV r1,r11 00002a 2010 MOVS r0,#0x10 00002c f7fffffe BL RES_RestartPC
Does someboby known a solution to get the current program counter?
Thanks Reto Felix
"Does someboby known a solution to get the current program counter?"
Maybe you should start your post with something very much more relevant: Telling us why you think you have a need to get the current program counter...
If it's hard to get the PC from a high-level language, it's because a normal program doesn't have a need to get the value of the PC.
