Hey Guys,
I am really in a desperate mode. I am new to this I2C and done some research about it, but unable to make it to work. I am using PCF8575C device and connect it according to the datasheet provided.
#include <REG51F.H> #include <stdio.h> #include <Input_Output.h> #include <Header_Display.h> //Function Declarations void initRS(); void I2C_Init(); //void Init_Low(); void I2C_Start(); //void I2C_Restart(); void I2C_Stop(); //void I2C_SendAck(); //void I2C_SendNack(); void Delay_1sec(); unsigned char I2C_Write(unsigned char Data); unsigned char I2C_Read(unsigned char Data); unsigned char i; unsigned char command; #define SDA p0_0 #define SCL p0_1 //Main function void main() { initRS(); initLED_BLINK(); header_display(); I2C_Init(); while((command = _getkey ()) != 0x1B){ // Waiting for key input from user switch(command){ case 'b': I2C_Start(); I2C_Write(0x4C); I2C_Write(0xAA); I2C_Write(0xF0); I2C_Stop(); break; case 'c': I2C_Start(); I2C_Read(0x4C); I2C_Stop(); break; case 'd': I2C_Start(); I2C_Write(0xF0); break; case 'e': I2C_Stop(); break; case 'f': I2C_Start(); break; case 'g': I2C_Init(); break; case 'i': SDA = 0; Delay_1sec(); SDA = 1; break; case 'j': SCL = 0; Delay_1sec(); SCL = 1; break; } } } // Function : Master sending START condition, HIGH to LOW transition on SDA while SCL keeping high void I2C_Start() { SDA = 1; Delay_1sec(); SCL = 1; Delay_1sec(); SDA = 0; Delay_1sec(); SCL = 0; Delay_1sec(); } //Function : I2C Write Byte transfer 3 bytes unsigned char I2C_Write(unsigned char Data) { unsigned char i, ack_bit; // Variable to be used in for loop for(i=0;i<8;i++) // Repeat for every bit { SCL = 0; // Make SCL pin low // the start condition should have exited low ! Delay_1sec(); // Data pin should change it's value, if ((Data & 0x80) == 0) // <<<< SDA = 0; else SDA = 1; Delay_1sec(); SCL = 1; Data<<=1; Delay_1sec(); } SCL=0; // all routines must exit with clock low, or bus clear ! Delay_1sec(); if(Data) ack_bit = SDA; SCL = 1; Delay_1sec(); SCL = 0; Delay_1sec(); return !ack_bit; } // Function : I2C Read Byte unsigned char I2C_Read(unsigned char Data) { unsigned char i; for(i=0;i<8;i++) { SCL = 0; Delay_1sec(); SCL = 1; Delay_1sec(); Data |=1; if(i<7) Data <<=1; } SCL = 0; Delay_1sec(); SDA = 1; Delay_1sec(); return Data; } // Function : To set initial values of SDA and SCL void I2C_Init() { SDA = 0xFF; SCL = 0xFF; } /*void Init_Low() { SDA = 0; Delay_1sec(); SCL = 0; } void I2C_Restart() { SDA = 1; Delay_1sec(); SCL = 1; Delay_1sec(); SDA = 0; Delay_1sec(); }*/ void I2C_Stop() { SDA = 0; Delay_1sec(); SCL = 1; Delay_1sec(); SDA = 1; } /*void I2C_Ack() { SDA = 0; Delay_1sec(); SCL = 1; Delay_1sec(); SCL = 0; } void I2C_Nack() { SDA = 1; SCL = 1; SCL = 0; }*/ void Delay_1sec() // Delay for 0.1 second { unsigned int x,y; for(x=0; x<1000; x++) { for(y=0; y<21; y++) {} } } }
Please do help me. This is my code. Someone gave me this code and I tried it. It works even with a different address. Please help me. I really need it.
Thanks!
