Hello!
I have recently noticed that when you have a non empty std::vector it has a minimum capacity of 32 elements. No matter how big the elements are. So I was wondering if this can be set to a different value. On windows the vector capacity grows nicely from 1 onwards.
Example:
struct BigStruct { char k; int i[100]; }; void minSizeTest() { std::vector<int> vec(10, 1337); // vec.size() == 10, vec.capacity() == 32 std::vector<BigStruct> vBig(10); // same as above! 32*sizeof(BigStruct) is a lot for my microprocessor :) }
