STM32F103VCT USART2 False Reception issue
I would need 3 USARTs for a project (I am using stm32f103vct6 microcontroller). One USART is already functional properly which is USART1. I am trying same with USART2. Transmit is working fine but but RXNE flag is falsely setting up here and hence its giving garbage Rx character. I tried same code using arm-none-linux-gcc compiler in which its working fine (no false RXNE flag setting), hence i thought it could be compiler related issue. I am posting my code for reference.
void USART2_Init(void)
                        GPIO_InitTypeDef GPIO_InitStructure;
                        USART_InitTypeDef USART_InitStructure;
                        //enable bus clocks
                        RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
                        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);
                        //Set USART2 Tx (PA2) as AF push-pull
                        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
                        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
                        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
                        GPIO_Init(GPIOA, &GPIO_InitStructure);
                        //Set USART2 Rx (PA3) as input floating
                        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
                        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
                        USART_InitStructure.USART_BaudRate = 115200;
                        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
                        USART_InitStructure.USART_StopBits = USART_StopBits_1;
                        USART_InitStructure.USART_Parity = USART_Parity_No ;
                        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
                        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
                        USART_Init(USART2, &USART_InitStructure);
                        //Enable USART2
                        USART_Cmd(USART2, ENABLE);
/* Usart functions ---------------------------------  ------------------------*/
* Function Name  : SerialPutChar
* Description    : Print a character on the HyperTerminal
* Input          : - c: The character to be printed
* Output         : None
* Return         : None
void SerialPutChar(u8 c)
        USART_SendData(USART2, c);
        while (USART_GetFlagStatus(USART2, USART_FLAG_TXE) == RESET);
int GetChar (void)
        while (USART_GetFlagStatus(USART2, USART_FLAG_RXNE) == RESET);
                return USART_ReceiveData(USART2);
* Function Name  : Serial_PutString
* Description    : Print a string on the HyperTerminal
* Input          : - s: The string to be printed
* Output         : None
* Return         : None
void Serial_PutString(u8 *s)
        while (*s != '\0')
        SerialPutChar(*s);
        s ++;
void main()
  int data;
          USART1_Init();
        Serial_PutString("This is test put string function on open source compiler\r\n");
                                  //printf("This is containing the printf debug command\r\n");
                  while(1)
                          data = GetChar();
                          SerialPutChar(data);
Please let me know what can be done to solve this. What i am missing in above code.
