Hi, I am looking for UART based secondary bootloader for LPC1768. Please clarify the following queries: When I am sending binary file from say UART, should I send .bin file or .hex file of the application code? Should it be interpreted(.bin / .hex) and written to flash ? or should it be written as it is (as generated from IDE) into flash using IAP?
Please Help and guide..!
Thank you ..
Think about it: what is the difference between a ".bin" file and a ".hex" file?
If you don't know, then google is your friend...
From understanding the difference, you should be able to think of the advantages & disadvantages of each - and how they relate to your specific requirements.
Only you know what is important/significant to your application...
As Andrew says you've got to think about what you've got to solve, and how/what you are capable of doing at each end of the connection. If you can write a PC app to send the code, or if you have to use Hyper Terminal or whatever. If you have to use a program built by someone else, the limits of that program (send file, X/Y/Z Modem, etc) will be an important factor.
Generally, I think binary would be a way of simplifying the micro-controller's job, and post-processing the IDE output into an idealized form. If your boot loader is more like a "monitor" application, loading hex is also workable, but might require some flow control, or buffering, so as not to overflow if the erase/flash is slow. Other protocols for X-Modem, or with ACK/NACK packets can be self paced, and have known buffering requirements.
