Hi , I m working on 89c51Ic2. I have created a variable like as below
unsigned char xdata buffer1[256] ; unsigned char xdata buffer2[256]; void initBuffer(void) { unsigned char i=0; for(i=0;i<256;i++) { buffer1[i]=0; buffer2[i]=0; } } void printubuffer(void) { unsigned char i=0; for(i=0;i<256;i++) { uartSendchar(buffer1[i]); uartSendchar(' '); uartSendchar(buffer2[i]); } } void main() { initBuffer(); while(1) { printubuffer(); delay(1000); //delay in ms } }
note: in the above uartSendchar(char data) and delay(int) are working fine, so i dint added details about that. I have included all corresponding header files. Problem: >> For me buffer1 values is always showing with number from 0 to 255. its not printing always 0. buffer2 is showing 0.I got confused in this please help me to solve this issue >> I have used standard 8051 startup code please refer below startup code, please correct me if anything is wrong, i dont have clear knowledge about startup code, please help me
================================================= startup.A51 =============== $NOMOD51 ; User-defined <h> Power-On Initialization of Memory IDATALEN EQU 100H XDATASTART EQU 0 XDATALEN EQU 0x3FF PDATASTART EQU 0H PDATALEN EQU 0H ;</h> ;------------------------------------------------------------------------------ ; ;<h> Reentrant Stack Initialization IBPSTACK EQU 1 ; set to 1 if small reentrant is used. IBPSTACKTOP EQU 0xFF +1 ; default 0FFH+1 ; </h> PBPSTACK EQU 0 ; set to 1 if compact reentrant is used. PBPSTACKTOP EQU 0xFF +1 ; default 0FFH+1 ; </h> ;</h> XBPSTACK EQU 0 ; set to 1 if large reentrant is used. XBPSTACKTOP EQU 0xFFFF +1 ; default 0FFFFH+1 ; </h> ;------------------------------------------------------------------------------ PPAGEENABLE EQU 0 ; set to 1 if pdata object are used. PPAGE EQU 0 ; ; <o> SFR address which supplies uppermost address byte <0x0-0xFF> ; most 8051 variants use P2 as uppermost address byte PPAGE_SFR DATA 0A0H ; ; </e> ;------------------------------------------------------------------------------ ; Standard SFR Symbols ACC DATA 0E0H B DATA 0F0H SP DATA 81H DPL DATA 82H DPH DATA 83H NAME ?C_STARTUP ?C_C51STARTUP SEGMENT CODE ?STACK SEGMENT IDATA RSEG ?STACK DS 1 EXTRN CODE (?C_START) PUBLIC ?C_STARTUP CSEG AT 0 ?C_STARTUP: LJMP STARTUP1 RSEG ?C_C51STARTUP STARTUP1: IF IDATALEN <> 0 MOV R0,#IDATALEN - 1 CLR A IDATALOOP: MOV @R0,A DJNZ R0,IDATALOOP ENDIF IF XDATALEN <> 0 MOV DPTR,#XDATASTART MOV R7,#LOW (XDATALEN) IF (LOW (XDATALEN)) <> 0 MOV R6,#(HIGH (XDATALEN)) +1 ELSE MOV R6,#HIGH (XDATALEN) ENDIF CLR A XDATALOOP: MOVX @DPTR,A INC DPTR DJNZ R7,XDATALOOP DJNZ R6,XDATALOOP ENDIF IF PPAGEENABLE <> 0 MOV PPAGE_SFR,#PPAGE ENDIF IF PDATALEN <> 0 MOV R0,#LOW (PDATASTART) MOV R7,#LOW (PDATALEN) CLR A PDATALOOP: MOVX @R0,A INC R0 DJNZ R7,PDATALOOP ENDIF IF IBPSTACK <> 0 EXTRN DATA (?C_IBP) MOV ?C_IBP,#LOW IBPSTACKTOP ENDIF IF XBPSTACK <> 0 EXTRN DATA (?C_XBP) MOV ?C_XBP,#HIGH XBPSTACKTOP MOV ?C_XBP+1,#LOW XBPSTACKTOP ENDIF IF PBPSTACK <> 0 EXTRN DATA (?C_PBP) MOV ?C_PBP,#LOW PBPSTACKTOP ENDIF MOV SP,#?STACK-1 #if 0 ; Initialize bank mechanism to code bank 0 when using L51_BANK.A51 with Banking Mode 4. EXTRN CODE (?B_SWITCH0) CALL ?B_SWITCH0 ; init bank mechanism to code bank 0 #endif ;</h> LJMP ?C_START END =================================================
please help me, if anything wrong in startup.a51 please correct me, tool details: uvision4: V4.53.0.6 C51:v9.50a assembler: A51 8.02b BL51: v6.22 LIB51: v4.29
Good. Thanks for feedback.
Did you observe Erik's note about where (within startup.a51) that needs to be done...?
Thanks u, I fixed this issue by enabling xram. I configured AUXR register to enable xram in startup code, then its started working.
Are you sure that you have the XDATA correctly configured in the chip...? just a note: this must be done before xdata init in startup
