Hi all,
I have try to develop an ethernet bootloader via tftp. First program (bootloader is placed in 0x0000-0xFFFF adress area) gets bin file from tftp-server and flashes it to from 0x10000 to the end of IROM. After all it jumps using this:
__asm void boot_jump( uint32_t address ) { LDR SP, [R0] ;Load new stack pointer address LDR PC, [R0, #4] ;Load new program counter address } /** * @brief Jump to second program * * @param address */ void jumpToProgram (uint32_t address) { SCB->VTOR = address & 0x3FFFFF80; boot_jump(address); } //some code here ... // jumping to second program from bootloader else if(memcmp("jump\r", str, strlen("jump\r")) ==0 ) { vTaskEndScheduler(); jumpToProgram(0x10000); } ... //some code here
Second program is shifted to 0x10000 by compiler (IROM1 start parametr is 0x10000). It works if I don't use any RTOS in second program. If I do, then program crashes at starting sheduler (vTaskStartScheduler() in FreeRtos or os_sys_init() in RTX). Furthermore I figured out that if I exclude frome bootloader file EMAC_LPC177x_8x.c the second program starts working (sheduler starts) after jumping in it from bootloader. What is wrong? Regards Vasilij
Have you remapped your interrupts, so the processor doesn't go looking for ISR handlers in the boot loader address range?
And have you made sure you haven't switched protection mode in the boot loader startup file?
Per Westermark , Thank you for your reply.
SCB->VTOR = address & 0x3FFFFF80; <--- This is remaping interupt vectors. And yes I sure about protection mode.
Problem solved! I call SystemInit in second program. It reinitialize VTOR to 0x0000 value:
void SystemInit (void) { //some code ... #ifdef __RAM_MODE__ SCB->VTOR = 0x10000000 & 0x3FFFFF80; #else SCB->VTOR = 0x00000000 & 0x3FFFFF80; #endif }
So I should to remap vectors in second program after systemInit or shouldn't call systemInit in second program.
