Return Pointer to local string, destroys the string or not?
This forum may not be the best to ask the question, but the answers on the other forums (that i know) were generally with respect to C for desktop pc (where memory management is different from that in embedded) and this forum has knowledgeable embedded people. hence...
I was worried about the following situation:
void function1()
  ...     //other variables
  char* ptr = myary;
  ptr = ReadNandFlash("myfile");
char* ReadNandFlash(char* Filename)
  FILE* file;
  char temp_ary[256];
  file = fopen(Filename, "r");
  if(file == NULL)
    return NULL;
  while(!feof(file))
    fread(temp_ary, sizeof(char), 256, file);
  fclose(file);
  return ary;
will the 'temp_ary' be destroyed as only the pointer value is returned back to the function1()?
