I'm developing a camera with Omnivsion OV9655 image sensor on LPC1788 board. I am capturing 320x240 image and got the image but image is not clear some blur is there in some portion of image.
currently I am using following clock signals for OV9655.
XCLK = 14 Mhz (XCLK is generated by PWM) PCLK(Pixel clock) = 417.4 KHz frame Rate : 30 fps. frame Type : VGA Output Formats(8-bits) : RGB565
code flow :
(1) Initialize pin configuration for OV9655 (2) Initialize PWM for XCLK generation. (3) Initialize I2C with 1Khz clock speed. (4) Reset the OV9655 Camera module. (5) Configure register of OV9655 through I2C. (6) Start the Capture. (7) Capture the Image using polling method. For polling method I am following below steps.
(i) wait till VSYNC be come High. (ii) wait till VSYNC be come LoW. (iii)Now, wait till HREF be come High (iv) Wait for rising edge of the PCLK (v) Read data from parallel data lines and stored into SDRAM. (vi) follow steps (iv) and (v) until HREF become LOW. (vii) follow steps (iii) to (vi) until VSYNC be come High.
(8) Convert captured image output formats RGB565(16 bits) to RGB888(24 bits) (9) Send convert image to PC as .BMP
On computer BMP image is not clear, blur is there in some portion of the image. But in my code if I repeat Camera register configuration 2 or 3 times then image became clear. I can't get this problem, please suggest me some solution for this blur image.
Below are the OV9655 Registers settings:
// Settings(VGA)320*240
{ 0x12, 0x80 }, { 0x00, 0x00 }, { 0x01, 0x80 }, { 0x02, 0x80 }, { 0x03, 0x02 }, { 0x04, 0x03 }, { 0x0b, 0x57 }, { 0x0e, 0x61 }, { 0x0f, 0x40 }, { 0x11, 0x04 }, { 0x12, 0x63 }, //62 { 0x13, 0xc2 }, //c7 { 0x14, 0x3a }, { 0x15, 0x20 }, //added extra { 0x16, 0x24 }, { 0x17, 0x18 }, { 0x18, 0x04 }, { 0x19, 0x01 }, { 0x1a, 0x81 }, { 0x1e, 0x04 }, { 0x24, 0x3c }, { 0x25, 0x36 }, { 0x26, 0x72 }, { 0x27, 0x08 }, { 0x28, 0x08 }, { 0x29, 0x15 }, { 0x2a, 0x00 }, { 0x2b, 0x00 }, { 0x2c, 0x08 }, { 0x32, 0x24 }, // { 0x33, 0x00 }, { 0x34, 0x3f }, { 0x35, 0x00 }, { 0x36, 0x3a }, { 0x38, 0x72 }, { 0x39, 0x57 }, { 0x3a, 0x8c }, // { 0x3b, 0x04 }, // { 0x3d, 0x99 }, { 0x3e, 0x0e }, // { 0x3f, 0xc1 }, // { 0x40, 0xd0 }, { 0x41, 0x01 }, // { 0x42, 0xc0 }, { 0x43, 0x0a }, { 0x44, 0xf0 }, { 0x45, 0x46 }, { 0x46, 0x62 }, { 0x47, 0x2a }, { 0x48, 0x3c }, { 0x4a, 0xfc }, { 0x4b, 0xfc }, { 0x4c, 0x7f }, { 0x4d, 0x7f }, { 0x4e, 0x7f }, { 0x4f, 0x98 }, { 0x50, 0x98 }, { 0x51, 0x00 }, { 0x52, 0x28 }, { 0x53, 0x70 }, { 0x54, 0x98 }, { 0x58, 0x1a }, { 0x59, 0x85 }, { 0x5a, 0xa9 }, { 0x5b, 0x64 }, { 0x5c, 0x84 }, { 0x5d, 0x53 }, { 0x5e, 0x0e }, { 0x5f, 0xf0 }, { 0x60, 0xf0 }, { 0x61, 0xf0 }, { 0x62, 0x00 }, { 0x63, 0x00 }, { 0x64, 0x02 }, { 0x65, 0x20 }, { 0x66, 0x00 }, // { 0x69, 0x0a }, { 0x6b, 0x0a }, //5a { 0x6c, 0x04 }, { 0x6d, 0x55 }, { 0x6e, 0x00 }, { 0x6f, 0x9d }, { 0x70, 0x21 }, { 0x71, 0x78 }, { 0x72, 0x11 }, { 0x73, 0x01 }, { 0x74, 0x10 }, { 0x75, 0x10 }, { 0x76, 0x01 }, { 0x77, 0x02 }, { 0x7A, 0x12 }, { 0x7B, 0x08 }, { 0x7C, 0x16 }, { 0x7D, 0x30 }, { 0x7E, 0x5e }, { 0x7F, 0x72 }, { 0x80, 0x82 }, { 0x81, 0x8e }, { 0x82, 0x9a }, { 0x83, 0xa4 }, { 0x84, 0xac }, { 0x85, 0xb8 }, { 0x86, 0xc3 }, { 0x87, 0xd6 }, { 0x88, 0xe6 }, { 0x89, 0xf2 }, { 0x8a, 0x24 }, { 0x8c, 0x80 }, { 0x90, 0x7d }, { 0x91, 0x7b }, { 0x9d, 0x02 }, // { 0x9e, 0x02 }, // { 0x9f, 0x7a }, { 0xa0, 0x79 }, { 0xa1, 0x40 }, { 0xa4, 0x50 }, { 0xa5, 0x68 }, { 0xa6, 0x4a }, { 0xa8, 0xc1 }, { 0xa9, 0xef }, { 0xaa, 0x92 }, { 0xab, 0x04 }, { 0xac, 0x80 }, { 0xad, 0x80 }, { 0xae, 0x80 }, { 0xaf, 0x80 }, { 0xb2, 0xf2 }, { 0xb3, 0x20 }, { 0xb4, 0x20 }, { 0xb5, 0x00 }, { 0xb6, 0xaf }, //{ 0xb6, 0xaf }, //repeat { 0xbb, 0xae }, { 0xbc, 0x7f }, { 0xbd, 0x7f }, { 0xbe, 0x7f }, { 0xbf, 0x7f }, //{ 0xbf, 0x7f },//repeat { 0xc0, 0xaa }, { 0xc1, 0xc0 }, { 0xc2, 0x01 }, { 0xc3, 0x4e }, { 0xc6, 0x05 }, { 0xc7, 0x81 }, { 0xc9, 0xe0 }, { 0xca, 0xe8 }, { 0xcb, 0xf0 }, { 0xcc, 0xd8 }, { 0xcd, 0x93 }, //{ 0x40, 0x10 }, //
Note that some cameras can blur (or completely mask) some parts of an image - so a traffic camera might mask away the face of a car passenger.
Make sure that the blur isn't caused by dirty optics, dirty sensor or by firmware in the camera.
Thanx for the reply Per, but as I have already written that when I reinitialize my camera registers two or more times this blurness goes. So, I dont think that this blurness is because of dirty optics, dirty sensor or by firmware in the camera. Do you have register settings for OV9655 camera for 320 * 240 image with RGB output format.
