Product DCD 0 ;0 EXPORT Product FirmwareVer DCD 0x00000001 Version, cc = Major Version EXPORT FirmwareVer
After removing above lines from my startup file(filename.s), my application doesn't even make it to main() or __main(). When I undo this change, I am running.
Please advise!
Why do you want to remove it?. some in the startup is pretty clear, some is 'secret sauce' required for the compiled code to run.
