Product DCD 0 ;0 EXPORT Product FirmwareVer DCD 0x00000001 Version, cc = Major Version EXPORT FirmwareVer
After removing above lines from my startup file(filename.s), my application doesn't even make it to main() or __main(). When I undo this change, I am running.
Please advise!
Those lines consume memory. When you remove them, other stuff will change its position.
You have 2 options:
1. Find what is the critical thing that's moving, and adjust accordingly;
2. Leave the lines (or equivalent) in!
You haven't given any information to allow anyone to help you with option 1.
Product ID and Firmware Version are defined in this file and refrenced in another file. We don't need to hardcode these Two identifiers in this file because they will be fetched from another controller over modbus. Therefore, I would like to completely remove them from this file. They don't belong to this file anymore.
Could someone refer me to a source that explains this in detail ?
Thank you!
So you could just put dummies in their place.
It's not rocket science!
Unless you specifically specify otherwise, memory is allocated in order - so, if you remove some stuff, then the stuff that remains will obviously get allocated at lower addresses.
You should be able to see this in the Map file...
Perhaps someone within your organization can explain the purpose and impact of these structures/values. The random data supplied so far isn't going to be enough for third parties to figure out what's going on here.
You should also be able to turn off "run to main" and trace through your code and better understand it and it's behaviour.
"Those lines consume memory."
Even better: if you delete all the start-up code and your own code, no memory will be consumed!
I know exactly what these lines of code mean. They are defined in this file and externed in C++ file. We don't need these two variables anymore because our architecture has changed.
I'm asking how I can rewrite assembly language .s file with these definitions removed so everything is in correct position ?
Do you honestly believe you've provided enough information for anyone not familiar with this particular file, and the lines surrounding the four you've shared, to understand why they are critical?
