Hi, I wonder does the subject work in Keil uVision? Because in debug configuration window I see both connected cores, but regardless of which one I choose, uVision always connects to the last one. In the meantime all SEGGER utils work just fine, so my connection is OK. I found similar case on SEGGER forums, on the 14 of March there is an answer: >We are already in contact with Keil regarding this. >Will be fixed/changed but not short term, since this probably requires major changes in the uVision <-> J-Link DLL interface DLL. >Not short term means: Probably 4-8 weeks.
So my question is: do you have any ETA on this fix? And maybe for now you can give me some advice on how to get around this problem.
