Hello, i wanted to ask if anyone know whats wrong with this code when i want to send letters to my display with the hd44780 but it wont work it only works when its in a loop otherweise it simply wont show anything.
main.c
#include <91x_lib.H> #include "lcd.h" int main(void) { LCD_init(); LCD_putstring("abc"); SCU->PRR1 |= __GPIO7 | __GPIO3; SCU->PCGR1 |= __GPIO7 | __GPIO3; SCU->GPIOTYPE[7]=0x00; SCU->GPIOOUT[7]=0x5555; GPIO7->DDR=0xff; SCU->GPIOIN[3]=0x00; GPIO3->DDR=0; while(1) { //LCD_control(ON,BLINK,SHOW); GPIO7->DR[0xf0<<2]=~GPIO3->DR[0xf0<<2]; } }
lcd.h
#ifndef __LCD_H #define __LCD_H #define BLINK 0x01 // Alias for blinking cursor #define NOBLINK 0x00 // Alias for non blinking cursor #define SHOW 0x02 // Alias for cursor on #define HIDE 0x00 // Alias for cursor off #define ON 0x04 // Alias for display on #define OFF 0x00 // Alias for display off void LCD_init(void); void LCD_putchar(unsigned char value); void LCD_putstring(char *str); void LCD_control(unsigned char dsp,unsigned char blink,unsigned char cursor); void LCD_setpos(unsigned char p); void LCD_clear(void); #endif
lcd.c
#include "91x_map.h" #include "91x_scu.h" // LCD Port access macros #define LCD_DATA(x) { GPIO8->DR[0x3fc] = (x); }; #define CLR_E { GPIO9->DR[0x3fc] &= ~(1<<0); } #define SET_E { GPIO9->DR[0x3fc] |= (1<<0); } #define CLR_RS { GPIO9->DR[0x3fc] &= ~(1<<2); } #define SET_RS { GPIO9->DR[0x3fc] |= (1<<2); } #define CLR_RW { GPIO9->DR[0x3fc] &= ~(1<<1); } #define SET_RW { GPIO9->DR[0x3fc] |= (1<<1); } static void LCD_delay(int cycles) { cycles*=50; while(cycles--) asm volatile ("nop"); } static void LCD_write(unsigned char value, int command) { CLR_RW; if(command) CLR_RS else SET_RS; #ifdef LCD_4BIT LCD_DATA((value>>4)&0xf); SET_E; LCD_delay(1); CLR_E; LCD_DATA((value)&0xf); SET_E; LCD_delay(1); CLR_E; #else LCD_DATA(value); SET_E; LCD_delay(1); CLR_E; #endif LCD_delay(4); } void LCD_init() { // disable reset signal for GPIO ports 8 and 9 SCU->PRR1 |= __GPIO8 | __GPIO9; // enable peripheral clock for GPIO ports 8 and 9 SCU->PCGR1 |= __GPIO8 | __GPIO9; // set output type to push-pull for all port 8 lines and lines 0-2 for port 9 SCU->GPIOTYPE[8] = 0x0000 ; SCU->GPIOTYPE[9] &= ~0x3f ; // set all port 8 lines to output (both registers below need to be set for GPIO to work) SCU->GPIOOUT[8] = 0x5555; GPIO8->DDR = 0xff; // set port 9 lines 0..2 to output SCU->GPIOOUT[9] &= ~0x3f ; SCU->GPIOOUT[9] |= 0x15 ; GPIO9->DDR |= 0x7; LCD_write(0x30, 1); LCD_delay(200); LCD_write(0x30, 1); LCD_delay(200); LCD_write(0x30, 1); LCD_delay(200); LCD_write(0x38, 1); LCD_write(0x01, 1); LCD_write(0x06, 1); LCD_write(0x0c, 1); LCD_write(0x02, 1); LCD_write(0x80, 1); LCD_delay(100); } void LCD_clear() { LCD_write(1, 1); LCD_delay(100); } void LCD_putchar(unsigned char value) { LCD_write(value,0); } void LCD_putstring(char *str) { while(*str) LCD_putchar(*str++); } void LCD_control(unsigned char dsp,unsigned char blink,unsigned char cursor) { unsigned char control; // variable to generate instruction byte control = (0x08 + blink + cursor + dsp); // Cursor control LCD_write(control, 1); LCD_delay(100); } void LCD_setpos(unsigned char p) { LCD_write(0x80 | p, 1); LCD_delay(10); }
Isthere anyone who could help me with my problem:) ??
I'm not sure any readers are able to understand what you mean by "but it wont work it only works when its in a loop otherweise it simply wont show anything".
You really should consider describing your issues better than that if you want anyone to even start looking at your source code.
I mean that when im using the LCD_putstring("abc"); function outside the while loop the display shows nothing but when its in the loop it puts abc as long as the power is on thats what i mean :)
Given that the STR912 can run at 96mips, at a rough guess, your' delays are not sufficient, Specifically recall from memory that the HD44780 requires 4.1mS delays during init, my rough guess is that you are only providing 100-200uS. The other delays need to be looked at too!
- Why it may work 'in the loop' is probably that the LCD gets hit with the command over and over, eventually satisfying the timing requirements.
- Best practice is to use a hardware timer for timing delays then you can set delays up relative to the processor clock, and not depend on the way the compiler chooses to compile the delay loop, eg different compilers, compile options, different compiler versions etc. will screw you in the long term... I call software delay loops evil loops!
- Phil.
Thanks, it would be really nice if you could show me an example how to make it an how to setup the pll to 96 MHz .
So it is your view, that this forum, the manufacturer home page etc, have much too little information about how to use hardware timers for your platform? Can you link some of the examples you have found, and tell where you find them lacking?
