HI I'm going to RAM2 on LPC1768 microcontroller will activate the program KEIL I want to put a variable in RAM2 If you have information about a friend who can help me Thank you
Can't you do it with the Target options pane, or with a scatter file? And use directives or pragmas to drive placement?
thank you for answer But is this attribute LPC EXPRESSO Do you believe there's no way in keil
