Hi Guys,
I have just tested the new Uvision 5 prerelease version on a stm32f4 discovery board. I quite like the new concept of Run Time Environment where you just tick the peripherals you need and it automatically loads in the IDE.
Great! But when you load in the stm32 peripherals it calls for a stm32f3xx_conf.h When I import that in, the compiler says that file conflicts with GPIO drivers (middleware library in Keil).
Do you guys have a solution? The reason why importing STM32 libs are important is because all their sensor drivers somehow link with them.
Thanks. Jess
I have just tested the new Uvision 5 prerelease version \ when I let out a prerelease I want my customers to report all problems directly to me, not in a user forum, Contact Keil support directly.
If you are using the eval and do not have access through the normal support channel, find an e-mail address to send it to
