FTP server with FatFS
Hi
I am using ELM-Chan FatFS library and I need to set it as file system manager for TCPlib FTP server.
I do some changes in ftp_uif.c like this:
#include "header.h"
#define num_of_ftp_file 10
FIL     fsrc[num_of_ftp_file];
BOOL    FILE_inuse[num_of_ftp_file]={__FALSE};
void *ftp_fopen (U8 *fname, U8 *mode) {//done by ali
        FRESULT res;
        U8 cnt;
        FILE *ret;
        for(cnt=0;cnt<num_of_ftp_file;cnt++){
                if (FILE_inuse[cnt]==__FALSE){
                        break;
        if (cnt==num_of_ftp_file) return NULL;
        printf("fopen");
        if (mode[0]=='r'){
                res = f_open(&fsrc[cnt], (char *)fname+1, FA_OPEN_EXISTING | FA_READ);
                printf("\tr%d> %s\r\n",res,(char *)fname);
        else if (mode[0]=='w'){
                res = f_open(&fsrc[cnt], (char *)fname+1, FA_CREATE_NEW | FA_WRITE);
                printf("\tw%d> %s\r\n",res,(char *)fname);
        else if (mode[0]=='a'){
                res = f_open(&fsrc[cnt], (char *)fname+1, FA_OPEN_ALWAYS);
                printf("\ta%d> %s\r\n",res,(char *)fname);
        else
                return NULL;
        if (res!=FR_OK)
                return NULL;
        printf("file no:%d\r\n",cnt);
        FILE_inuse[cnt]=__TRUE;
        ret->handle=cnt;
        return (ret);
void ftp_fclose (void *file) {//done by ali
        FILE *fno=(FILE *)file;
        int no=fno->handle;
        FILE_inuse[no]=__FALSE;
        printf("file closed:%d\r\n",no);
        f_close(&fsrc[no]);
U16 ftp_fread (void *file, U8 *buf, U16 len) {//done by ali
        int no=fno->handle;
        U32 res;
        f_read (&fsrc[no], buf,len,&res);
        return res;
U16 ftp_fwrite (void *file, U8 *buf, U16 len) {
        int no=fno->handle;
        U32 res;
        f_write(&fsrc[no], buf, len, &res);
        f_sync(&fsrc[no]);
        return res;
BOOL ftp_fdelete (U8 *fname) {//done by ali
  printf("file deleted:%s\r\n",(char *)fname);
  if (f_unlink ((char *)fname) == FR_OK) {
    return (__TRUE);
  return (__FALSE);
BOOL ftp_frename (U8 *fname, U8 *newn) {//done by ali
  /* Rename a file, return __TRUE on success. */
  if (f_rename((char *)fname, (char *)newn) == FR_OK) {
    return (__TRUE);
  return (__FALSE);
DIR Dir;
static FILINFO Finfo;
U8 getdir=0;
U16 ftp_ffind (U8 code, U8 *buf, U8 *mask, U16 buflen) {
  U32 rlen,v;
  U8 *tp;
  char *ptr="0:";
  volatile FRESULT res;
  if (getdir==0){
    res = f_opendir(&Dir, ptr);
    getdir=1;
  printf("code:%d\r\n",code);
  if (code < 4) {
  rlen = 0;
next:
        res=f_readdir(&Dir, &Finfo);
        printf("%s\r\n",Finfo.fname);
    if ((res != FR_OK) || !Finfo.fname[0]) return 0;
    if (Finfo.fname[0] == '.') {
      if ((Finfo.fname[1] == 0) || (Finfo.fname[1] == '.' && Finfo.fname[2]) == 0) {
        /* Ignore the '.' and '..' folders. */
        goto next;
    switch (code) {
      case 0:
        /* Return file size as decimal number. */
        rlen = sprintf ((char *)buf,"%d\r\n", Finfo.fsize);
        break;
      case 1:
        /* Return last-modified time in format "YYYYMMDDhhmmss". */
        rlen  = sprintf ((char *)buf,"%04d%02d%02d",
                         (Finfo.fdate >> 9) + 1980, (Finfo.fdate >> 5) & 15, Finfo.fdate & 31);
        rlen += sprintf ((char *)&buf[rlen],"%02d%02d%02d\r\n",
                         (Finfo.ftime >> 11), (Finfo.ftime >> 5) & 63, (Finfo.ftime & 31)*2);
        break;
      case 2:
      case 4:
        rlen = sprintf ((char *)buf,"%s\r\n", Finfo.fname);
        break;
      case 3:
      case 8:
      case 5:
        rlen  = sprintf ((char *)buf,"%02d-%02d-%02d",
                        (Finfo.fdate >> 5) & 15, Finfo.fdate & 31, (Finfo.fdate >> 9) + 1980);
        /* Convert time to "AM/PM" format. */
        v = (Finfo.ftime >> 11) % 12;
        if (v == 0) v = 12;
        if ((Finfo.ftime >> 11) < 12) tp = "AM";
        else                   tp = "PM";
        rlen += sprintf ((char *)&buf[rlen],"  %02d:%02d%s",v,(Finfo.ftime >> 5) & 63,tp);
        if (Finfo.fattrib & AM_DIR) {//AM_DIR
          rlen += sprintf ((char *)&buf[rlen],"%-21s","       <DIR>");
        else {
          rlen += sprintf ((char *)&buf[rlen],"%21d", Finfo.fsize);
        rlen += sprintf ((char *)&buf[rlen]," %s\r\n", Finfo.fname);
        break;
  if (rlen==0) getdir=0;
  return (rlen);
as you know Fatfs is some how different form FlashFS ... I have no any way to simulate as FILE struct except make an array of FIL as you can see in my code.
my first question is about it and is there any solution to do it.
another problem is about different browser:
this code is not complete but google chrome does not show any file. firefox is the same.
Internet explorer can show all of files in memory card.
from explorer I can see every thing.
from printf I found sometimes with chrome library send "code=8" and there was no condition about it.
I didn't check anything except ftp_ffind I know it is contain problem but this is my first step to implement FTP server based on FatFS
