Hi I have a function InitRAM This way it works:
unsigned char Flash_Data[512]; unsigned int AnalogMaxValues[8]; #define AnalogMaxValues_start 129 //byte number of AnalogMaxValues in flash block void InitRAM() { unsigned char i; unsigned int index,index2,a,b; memcpy(&Flash_Data, ConfigStartAddress, sizeof(Flash_Data)) ; //save Analog related values to SRAM for(i=0;i<8;i++) { index =AnalogMaxValues_start+2*i; index2=AnalogMaxValues_start+2*i+1; //index+1; a= Flash_Data[index]; b= Flash_Data[index2]; AnalogMaxValues[i] = a+ (b<<8); //this is a 2 byte variable } }
And AnalogMaxValues[i] have correct values But the code below should do the same, while it's not working
unsigned char Flash_Data[512]; unsigned int AnalogMaxValues[8]; #define AnalogMaxValues_start 129 //byte number of AnalogMaxValues in flash block void InitRAM() { unsigned char i; unsigned int index,index2,a,b; memcpy(&Flash_Data, ConfigStartAddress, sizeof(Flash_Data)) ; //save Analog related values to SRAM for(i=0;i<8;i++) { index =AnalogMaxValues_start+2*i; index2=AnalogMaxValues_start+2*i+1; //index+1; AnalogMaxValues[i] = (int)Flash_Data[index]+ ((int)Flash_Data[index2]<<8); } }
and Flash_Data[index] and Flash_Data[index2] seem to be the same while they are not I'm using Keil uVision Do you think I have a problem in the second code?
Sorry The first code doesn't work either I have to use it this way to work:
unsigned char Flash_Data[512]; unsigned int AnalogMaxValues[8]; #define AnalogMaxValues_start 129 //byte number of AnalogMaxValues in flash block void InitRAM() { unsigned char i; unsigned int index,index2,a,b; memcpy(&Flash_Data, ConfigStartAddress, sizeof(Flash_Data)) ; //save Analog related values to SRAM for(i=0;i<8;i++) { index =AnalogMaxValues_start+2*i; index2=index+1; a= Flash_Data[index]; b= Flash_Data[index2]; AnalogMaxValues[i] = a+ (b<<8); //this is a 2 byte variable } }
not index2=index+1;
memcpy(AnalogMaxValues, &Flash_Data[AnalogMaxValues_start], sizeof(AnalogMaxValues));
Better yet make a structure and access it via a pointer.
Thanks Westonsupermare I'm not sure if this could cause the problem but I'd be happy to write my code better by using structures But I don't know how I could do this for this code If it's not too many lines of code, would you mind showing me how exactly I could do it?
typedef struct _FLASH_DATA { unsigned RandomClutter[129]; // Better to have some natural alignment unsigned int AnalogMaxValues[8]; unsigned long AdditionalClutter[4]; unsigned long Checksum; // For integrity perhaps } FLASH_DATA; FLASH_DATA * Flash_Data = (FLASH_DATA *)ConfigStartAddress; // Address of your stuff in FLASH memory, wherever it is unsigned int AnalogMaxValues[8]; void InitRAM() { memcpy(&AnalogMaxValues[0], &Flash_Data->AnalogMaxValues[0], sizeof(AnalogMaxValues)); }
Should have been unsigned char RandomClutter[129]; damn the lack of edit here.
