simple code not always working
Hi
I have a function InitRAM
This way it works:
unsigned char Flash_Data[512];
unsigned int AnalogMaxValues[8];
#define AnalogMaxValues_start 129   //byte number of AnalogMaxValues in flash block
void InitRAM()
  unsigned char i;
  unsigned int index,index2,a,b;
  memcpy(&Flash_Data, ConfigStartAddress, sizeof(Flash_Data)) ;
  //save Analog related values to SRAM
  for(i=0;i<8;i++)
        index =AnalogMaxValues_start+2*i;
        index2=AnalogMaxValues_start+2*i+1; //index+1;
        a= Flash_Data[index];
        b= Flash_Data[index2];
        AnalogMaxValues[i]     = a+ (b<<8);  //this is a 2 byte variable
And AnalogMaxValues[i] have correct values
But the code below should do the same, while it's not working
void InitRAM()
  unsigned char i;
  for(i=0;i<8;i++)
        AnalogMaxValues[i] = (int)Flash_Data[index]+ ((int)Flash_Data[index2]<<8);
and Flash_Data[index] and Flash_Data[index2] seem to be the same while they are not
I'm using Keil uVision
Do you think I have a problem in the second code?
