hi there,
I am using Keil µVision 4 with NXP LPC11U35. I want to load a structure that contains mix type of variables (chars, integers, longs) using a char pointer. How can I set byte alignment so that no data are missed at the alignment?
Thanks in advance.
I have used the following code with no success. I am still missing data at char variables:
effort 1:
typedef __packed struct{ unsigned char soh; unsigned short sender; unsigned short receiver; unsigned char trq; unsigned int command; unsigned short packet; unsigned char stx; unsigned int address; unsigned char data[MAX_DATA_LENGTH]; unsigned int crc; unsigned char etx; unsigned short checksum; unsigned char eoh; }RS485_FRAME;
effort 2:
#pragma push #pragma pack(1) typedef __packed struct{ unsigned char soh; unsigned short sender; unsigned short receiver; unsigned char trq; unsigned int command; unsigned short packet; unsigned char stx; unsigned int address; unsigned char data[MAX_DATA_LENGTH]; unsigned int crc; unsigned char etx; unsigned short checksum; unsigned char eoh; }RS485_FRAME; #pragma pop
sorry my bad...
this works
