heyy.. everyone, I am using Keil uvision 4, coding in assembly language for 8051, but i am not able to locate the created hex file in the folder in which i am actaully creating... infact, it is not even being created i think... Checked almost everything... need your help guyz...
Did you also check the build log, to figure out exactly what was done or what wasn't done during the build?
Did that include checking the box which says, "Create Hex File"...?
