negative monocrome interted
Hi all! How can I write routine in negative mode (monocrome inverted) using an area of code? Who can help me? Are there special instructions in the new C book?
  • No, the old books probably describe the available operators, like ~(invert) and ^(exclusive or), will likely suffice.
    The term is MONOCHROME INVERTED. What display do you have? Do you have an image?
    Your problem is rather poorly expressed, perhaps you should refine the question so it contains more specifics about your issue, and what part of the task is causing you difficulty?
