How to solve "expected an expression" error?
Hello, I'm new to ARM and Keil tools. I'm using Keil uVision V4.71.2.0. Compiler is Armcc.Exe. Compiler version is v5.03.0.69.
I'm working on large code base. When I try to build code, I get the following error:
Build target 'proj1_Debug'
compiling RTX_Config.c...
C:\Keil\ARM\RV31\INC\RTX_lib.c(185): error: #29: expected an expression
Target not created
In RTX_lib.c, line 185 looks is as follows:
#if (__ARM__ && __RTA_RTX_CONFIG)
what might me the problem? Thanks in advance.
