WHEN I AM TRYING TO USE TIMER 2 IN 89S52 AS BAUD RATE GENERATOR .MY uVISION IS NOT RECOGNIZING THESE REGISTERS(TCLK,T2CON).WAT DO I DO..HELP NEEDED ASAP
Fix your caps lock, and then check if you include the header file for the correct processor. If you do, then open the file and have a look at it. Doesn't sound too hard, does it?
Fix your caps lock Absolutely.
it simply means that keil cannot find the correct definitions and/or declarations. Have you included the proper header file?
