Dear all I have made a custom board based on stm32f407IGT6 and used the same schematics from keil MBCSTM32F400 board, I have written this simple program for testing PING,
int main(void) { SysTick_Config(SystemCoreClock/100); /* Generate interrupt each 10 ms */ init_TcpNet (); while(1) { main_TcpNet(); } } void SysTick_Handler (void) { timer_tick (); }
Also I have made this change into Net_Config.c file
#define TICK_INTERVAL 10
my PC does show that it has found some activity on the lan and the link leds will light up and for a bout 1 minute the yellow led will blink too, but the board does not respond with the ping,
here are the content of ST802RT1A registers,
PHY_REG_CNTRL=0x00001000; PHY_REG_STATS=0x0000786D; PHY_REG_PHYID1=0x00000203; PHY_REG_PHYID2=0x00008461; PHY_REG_LDADV=0x000005E1; PHY_REG_LPADV=0x0000C1E1; PHY_REG_ANEGX=0x0000000F; PHY_REG_LDNPG=0x00002801; PHY_REG_LPNPG=0x00000000; PHY_REG_XCNTL=0x00001000; PHY_REG_XSTAT=0x00000300; PHY_REG_XRCNT=0x00000100; PHY_REG_XCCNT=0x000011D8; PHY_REG_XDCNT=0x0000000A; PHY_REG_AUXCS=0x0000002B; PHY_REG_AUXSS=0x0000F53E; PHY_REG_AUXM2=0x0000000A; PHY_REG_TSTAT=0x0000082B; PHY_REG_AMPHY=0x000080E0; PHY_REG_RN1F=0x00000000; PHY_REG_RS1B=0x0000000A;
Do you know what's going wrong?
