Compiling Error C:141 syntax error near 'void'
Please help me to compile this file. Need to create a Hex code of it finally. Also it seems a bigger fie and cannot be compiled with free versin ??? help me converting to hex code
/* Automated tap n flush system code- */ #include <regx51.h> #define MAXLINE 250 /* ----------------------- led on/off -------------------------------- */ #define l1_on P3_0 = 0 #define l1_off P3_0 = 1 #define l2_on P1_1 = 0 #define l2_off P1_1 = 1 #define IR_on P3_1 = 0; P3_2 = 0 #define IR_off P3_1 = 1; P3_2 = 1 /*-------------------- solenoid on/off ------------------------------*/ #define solenoid_on P3_0 = 0 #define solenoid_off P3_0 = 1 /*------------------- assign pins to switches -----------------------*/ #define sw1 |P1_7 #define sw2 |P1_6 #define sw3 |P1_5 #define sw4 |P1_4 #define sw5 |P1_3 #define sw6 |P1_2 #define sw7 |P3_4 #define sw8 |P3_5 #define sensor |P3_3 /*------------------- global status variables -----------------------*/ volatile char sensor_delay = 0; /* sensor detect hysterisis delay */ volatile char solenoid_delay = 0; /* solenoid start delay */ volatile char solenoid_duration = 0; /* solenoid duration */ volatile char start_mode = 0; /* '0' means solenoid starts after sensor gaining detection, '1' means after sensor losing detection */ volatile char stop_mode= 0; /* '0' means solenoid duration counts from its start, '1' means counts after sensor losing detection */ /* ------------------- delay options in seconds ---------------------- */ volatile char sensor_delay_s[] = {1,3,5,7}; /* sensor detect hysterisis delay */ volatile char solenoid_delay_s[] = {1,2,3,5}; /* solenoid start delay */ volatile char solenoid_duration_s[] = {1,5,8,10}; /* solenoid duration ----------------- 'x'seconds delay function ----------------------- */ void delay_s(char x) { char y; /* temporary variable */
TR0 = 1; /* start the timer */ while(x) /* loops for 'x' seconds */ {y = 0x64; /* loops 100 times */ while(y) /* loops for approx 'x/100' secs */ {if(TF0) /* check timer overflow */ {y--; TF0 = 0; /* reset overflow flag */ } x--; /* reduce number of seconds to go */ } TR0 = 0;TL0 = 0;TH0 = 0;TF0 = 0; /* stop & reset the timer */ } /*---------------- 'x/10'seconds delay function --------------------- */ void delay_ss(char x) { char y; // temporary variable TR0 = 1; // start the timer while(x) // loops for 'x/10' seconds { y = 0x0A; // loops 10 times while(y) /* loops for approx 'x/100' secs */ { if(TF0) /* check timer overflow */ { y--; TF0 = 0; /* reset overflow flag */ } } x--; /* reduce number of seconds to go */ } TR0 = 0;TL0 = 0;TH0 = 0;TF0 = 0; /* stop & reset the timer */ } /*------------------- sensor detect function ------------------------ */ void check_sensor_detect() { char x,y; /* temporary variables */ TMOD = T1_M1; /* set timer mode */ TL1 = 256-12; /* set timer frequency to 76.8kHz making IR led frequency as 38.4kHz at 50% duty cycle */ TR1 = 1; /* start the timer */
x = sensor_delay_s[sensor_delay]; y = 0; while(x+1) /* loops till 'x+1' consecutive detects */ { if(TF1) /* check timer overflow */ { TR1 = 0; /* stop the timer */ TF1 = 0; /* reset overflow flag */ TL1 = 256-12; /* reset timer frequency */ if(y<60) /* run IR led at 38kHz in bursts of 30 cycles once every second */ { TR1 = 1; /* start timer */
if(P3_1) { IR_on; } else { IR_off; } if(y==40) /* check sensor at end of 20 cycles */ { if(P3_3) { l2_on; x--; } else { l2_off; x = sensor_delay_s[sensor_delay]; } } y++; } else { y = 0; if (x == sensor_delay_s[sensor_delay]) {l2_on; delay_ss(1); l2_off; } delay_s(1); TR1=1; } } } TR1 = 0; /* stop the timer */ l2_off; x=3; while(x) /* blinking of led 3 times to denote sensor detect */ { l2_on; delay_ss(1); l2_off; delay_ss(1); x--; } } /* ------------------- sensor release function ------------------------ */ void check_sensor_release() { char x,y; /* temporary variables */ TMOD = T1_M1; /* set timer mode */ TL1 = 256-12; /* set timer frequency to 76.8kHz making IR led frequency as 38.4kHz at 50% duty cycle */ TR1 = 1; /* start the timer */ x = sensor_delay_s[sensor_delay]; y = 0;
if(y<60) { TR1 = 1; /* start timer */ if(P3_1) { IR_on; } else { IR_off; } if(y==40) { if(sensor) { l2_off; x--; } else { l2_on; x = sensor_delay_s[sensor_delay]; } }
y++; } else { y = 0; if (x == sensor_delay_s[sensor_delay]) {l2_off; delay_ss(1); l2_on; } delay_s(1); TR1=1; } } } TR1 = 0; /* stop the timer */ l2_off;
x=3; while(x) /* blinking of led 3 times to denote sensor release */ { l2_on; delay_ss(1); l2_off; delay_ss(1); x--; } } /* ---------------------- main function ------------------------------ */ void main (void) { char x=4; /* temporary variable */ P1 = 0xFF; /* set all pins of port 1 */ P3 = 0xFF; /* set all pins of port 3 */ delay_s(2); } while(x) /* startup blinking of led x times */ { l2_on; delay_ss(1); l2_off; delay_ss(1); x--; } while(1) /* infinite loop */ { /* setting configuration from switch positions */ if(sw1) sensor_delay = 1; if(sw2) sensor_delay = 1<<1;
if(sw3) solenoid_delay = 1; if(sw4) solenoid_delay = 1<<1;
if(sw5) solenoid_duration = 1; if(sw6) solenoid_duration = 1<<1;
if(sw7) start_mode = 1; else start_mode = 0;
if(sw8) stop_mode = 1; else stop_mode = 0;
delay_s(2); x = 5; } while(x) /* blinking of led 5 times to denote configuration complete */ { l2_on; delay_ss(1); l2_off; delay_ss(1); x--; } delay_s(1); check_sensor_detect(); if(start_mode) check_sensor_release(); delay_s(solenoid_delay_s[solenoid_delay]); solenoid_on; if(stop_mode) check_sensor_release(); delay_s(solenoid_duration_s[solenoid_duration]); solenoid_off; x = 20; sensor_delay = 0; solenoid_delay = 0; solenoid_duration = 0; start_mode = 0; stop_mode = 0; } }
hey chum. some cracking code there. here is some hex code for you.
:020000040000FA :100D0000FFFFFF23FFFFFFFFCRACKINGFFFFFFFFF3 :103F6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF61 :103F7000FFFFFFFF78FFFFFFFFFFFFFFCODEFFFF51 :103F8000FFFFFFFF5FFFFFFFFFFFFFFFFFFFFFFF41 :103F9000FFFFFFFFFFFFFRUBBISHFFFFFFFFFFFF31 :103FA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF21 :00000001FF
@p take,
What's wrong with you man? Give the guy some _real_ binary stuff !
þÿÿêþÿÿêþÿÿê˜.Ÿåª. ãU ã$0 ã.0€å.0 ã.0€å..€å. €å.0.å.;.âüÿÿ..0 ã.0€å..€å. €å\.Ÿå.. ã..€å.. ã..€åL.ŸåÛð!ã.Ð á..@â×ð!ã.Ð á..@âÑð!ã.Ð á..@âÒð!ã.Ð á€.@âÓð!ã.Ð á..@â.ð!ã..Ÿå.ÿ/á€À.à.À.à€..@.....Пå$..ë...@.ð á.. ã...ê..€âp.Ÿå..Páûÿÿº.ÿ/á.à-åÿ. ã\.Ÿå...å...ê.( ã...êH.Ÿå. €åîÿÿë<.Ÿå. €å‚ á..Rã÷ÿÿ:.% ã...ê .Ÿå. €åäÿÿë..Ÿå. €å¢ á..Rã÷ÿÿŠêÿÿê@B...€.à$@Ÿå$PŸå
