hi all iam using LPC1788 M3 cortex ARM 7 controller iam trying to execute the timer and serial interrupt program. in both the cases iam unable to return from the interrupt handler routine.
iam also working on LPC2378 ARM 7 controller where i have executed both the programs mentioned above. there iam using VICVECTADDR=0 to return from interrupt to main. what is the case in LPC1788? please help. Thanks in advance
Show the code, and use the PRE tags, the issue might be more apparent.
Cortex-M3 interrupt code and requirements should be a lot simpler, requiring straight C routines called directly via the NVIC.
Not returning? or stuck in a loop? If you fail to clear the source an M3 will keep calling the interrupt handler, and not run other code.
main() { // UART TX AND RX LINE SELECTION LPC_GPIO0->P0_0=0X1; LPC_GPIO->P0_1=0X1;
// UART INIT
LPC_UART0->LCR=0X80; // DLAB=1 LPC_UART0->DLL=78;//9600 BAUDRATE LPC_UART0->LCR=0X03;// 8BIT DATA LPC_UART0->IER = 0x01; // interrupt enable
NVIC_ENABLE(UART0_IRQn);
if(ch==0x24) { serial_send("AMS"); }
void serial_send(char *ch) { while(*ch!='\0') { while(!(LPC_UART0->LSR & 0x20)); LPC_UART0->THR = *ch; ch++; } }
void UART0_Handler(void) { ch=LPC_UART0->RBR; }
this is my code its not working......... here i am trying to execute interrupt.. when i type $ through keyboard then only it should send string AMS...... but its not coming out from interrupt handler....
when i put the same code which i have written in main i.e if(ch==0x24) in isr then it works fine.....
i dont want to place the code in isr.... i will just monitor ch value from isr if ch equals to dollar then it should come to main and execute the rest of program.....
