How do I calculate the execution time for a program?
I use a LPC2148(arm7) in uVision Keil Mdk. I get the dis-assembly listing when I compile any code.Suppose if I want to calculate the execution time for the code, one way is to find the number of cycles for execution each instruction,multiply it with the clock frequency,have a recursive addition for all the instructions and finally I can get it.. But I don want to do it manually. I want to develop an app where if I enter the dis-assembly listing and the clock frequency used, it must give me my execution time. we have the readily available dis-assembly listing for the respective code generated from the ide. But how do I proceed with that? I hope I am clear with my question..
Regards
Ram Prasadh
  • oh!! I will have a look on what is that...
    "Do you really want to do it?"
    This is my scenario. Suppose 10 people are writing a code for the working of LCD module for an arm7 uP. I want to find out the execution times of each code out there and obviously we will be having a code with the least and the high execution time. Depending on those time obtained,I am going to make an algorithm for execution of the a task(in this case,the LCD code is the task) for which I will be taking the computation time of the task as the least execution time which was obtained earlier and the deadline for the task as the highest execution time obtained.. I hope I am clear with what am going to do.. So , for making these stuffs possible , I need a program to find the execution times from the dis-assembly listing...
    The thing which you said just now, full-blown cycle-accurate simulator, will it suit my need??
    Regards
    RamPrasadh
    Regards
    RamPrasadh
