when i burnt the example hex file the hardware is working. but when the code i copied and compiled using keil uVision2 and converted to hex its not working what is the problem
You are obviously an idiot. I will not waste any more of my valuable time on you. Goodbye.
i am begginer to this microcontroller things. i am software developer from cs background, but i have interest in this. i am doing the basic led blink project same as example given with the software. when i copied the code and converted to hex it's not working.....what is the problem
If you created your own project but using same code as a working example, then it's time to check the project file options.
Does it build for the correct processor? The correct memory regions?
