Hi i'm using : MDK-ARM standard version 4.20 RL-ARM Real-Time library V4.13 LPC1788 i need to use ewin(segger) and TCP (RL) together . when i use each of them individually they work fine. but when i add TCP to ewin, the TCP doesn't work (doesn's answer my ping ) and my TCP driver is Emac_lpc17xx(i ported it for lpc1788)
i set a pin at the end of the "init_ethernet " function and it didn't set . but when i put it above of " iap_entry (&pb[0], &pb[0]);" it set.
so whats the problem ? even when i removed "iap_entry (&pb[0], &pb[0]);" because i knew that dev_175x = __FALSE;
iap_entry (&pb[0], &pb[0]); if ((pb[1] >> 24) == 0x25) { /* Use software RMII management routines. */ dev_175x = __TRUE; }
init_ethernet executed completely but now ENET_IRQHandler never happened !
so i'm really confused what should i do ?
is it possible they have memory conflict ?
Bump, I would like some tutorials to begin ARMS Asm...
actually i can't debug when i want debug i revive this :
Cannot access Memory *** error 57 :illegal address (0x00001000)
Get out your debugger to see exactly what is failing, and where.
Contact Keil support?
