Hi I wanted to control the servo motor according to the accelerometer value ,i developed the code using Arm wizard tool ,the code works well in Proteus tool but in hardware it fails , i checked the PWM output using the Oscilloscope can you help me to rectify the problem in the code
Code:
#include <LPC213x.h> void input(); void adc_ini(); void adc_data(); void pwm(); void motor(); void motorzero(); unsigned long val,adc_val; int main(void) { input(); pwm(); while(1) { adc_ini(); adc_data(); motor(); } } void input(void) { PINSEL0 = 0x00028000; IO0DIR = 0x80000000; PINSEL1 = 0x01000000; PINSEL2 = 0x00000000; IO1DIR = 0x00000000; } void adc_ini(void) { PCONP = (PCONP & 0x001817BE) | (1UL<<12); AD0INTEN = 0x00000000; AD0CR = 0x01200202; } void adc_data(void) { while((AD0DR & 0x80000000)==0); //until bit 31 is high (DONE) val = AD0DR; //read a/d data register adc_val = ((val >> 6) & 0x3FF); // Extract AD result } void pwm(void) { PCONP = (PCONP & 0x001817BE) | (1UL<<5); PWMTC = 0x00000000; PWMPR = 0x0000003B; PWMMCR = 0x00000002; PWMMR0 = 0x000003E8; PWMMR2 = 0x0000004B; PWMMR4 = 0x0000004B; PWMPCR = 0x00001400; PWMTCR = 0x09; } void motor(void) { if ((adc_val>=0x0000020E) && (adc_val<0x00000224)) { PWMMR2 = 0x0000004C; PWMMR4 = 0x0000004A; PWMLER = 0x00000014; } else if ((adc_val>=0x00000224) && (adc_val<0x00000238)) { PWMMR2 = 0x0000004D; PWMMR4 = 0x00000049; PWMLER = 0x00000014; } else if ((adc_val>=0x00000238) && (adc_val<0x0000024C)) { PWMMR2 = 0x0000004E; PWMMR4 = 0x00000048; PWMLER = 0x00000014; } else if ((adc_val>=0x0000024C) && (adc_val<0x00000260)) { PWMMR2 = 0x0000004F; PWMMR4 = 0x00000047; PWMLER = 0x00000014; } /*for negative angle*/ else if ((adc_val<=0x000001B8) && (adc_val>0x000001A3)) { PWMMR2 = 0x0000004A; PWMMR4 = 0x0000004C; PWMLER = 0x00000014; } else if ((adc_val<=0x000001A3) && (adc_val>0x0000018F)) { PWMMR2 = 0x00000049; PWMMR4 = 0x0000004D; PWMLER = 0x00000014; } else if ((adc_val<=0x0000018F) && (adc_val>0x0000017A)) { PWMMR2 = 0x00000048; PWMMR4 = 0x0000004E; PWMLER = 0x00000014; } else if ((adc_val<=0x0000017A) && (adc_val>0x00000167)) { PWMMR2 = 0x00000047; PWMMR4 = 0x0000004F; PWMLER = 0x00000014; } else { motorzero(); } } void motorzero(void) { PWMMR2 = 0x0000004B; PWMMR4 = 0x0000004B; PWMLER = 0x00000014; }
thanks in advance
"but in hardware it fails"
Was there a specific reason why you decided to not supply us with any information at all about what happened/didn't happen? My car fails: what is wrong?
According to the code the the function pwm() has to be executed before the while loop. but there is no signal of pwm pulse on the oscilloscope when i press the reset button on the hardware,and then according to the ADC results condition the pulse width of the pwm has to be varied but those condition is not working, i am getting the PWM output when i turn the POT to minimum position (The waveform is as per the initialization pwm function and it is pulse is not varying).
