I have installed keil uvision 4 on my pc.I worked on it and for past 2 days i didn't worked on it and now i'm getting an exception error like as below
--------------------------- µVision4: Uv4.exe - Application Error --------------------------- The exception unknown software exception (0x40000015) occurred in the application at location 0x0080f303.
Click on OK to terminate the program Click on CANCEL to debug the program --------------------------- OK Cancel ---------------------------
please mail me about proper installation of keil uvision4 and where i can find the .exe file for it.Answer for the above exception error.
with regards,
thank you
And then you found this forum, and failed to notice that the forum is for end-users, and not a route for official support?
You haven't noticed the "Contact" link at bottom of web page or the "Support" menu choice at top of page?
I can't understand how to solve that problem.Keil uvision4 is not opening yet.please reply me.
Are you saying that you are unable to understand how to click that "Support" menu choice at top of the Window, and then create a support request?
Invoking project defined compiler. C:\SiLabs\Keil\C51\BIN\C51.EXE "code.c" DB OE QUIET INTXD OT(6,Speed) PIN(C:\SiLabs\MCU\Inc;C:\SiLabs\Keil\C51\inc;C:\SiLabs\Keil\C51\inc\51)
C51 COMPILER V7.05 - SN: K1C5U-J4828D COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2003 C51 FATAL-ERROR - ACTION: PARSING INVOKE-/#PRAGMA-LINE LINE: C:\SiLabs\Keil\C51\BIN\C51.EXE code.c DB OE QUIET ERROR: UNKNOWN CONTROL C51 TERMINATED.
Hello Sir,
While using the silabs ide when i have to compile the code iam getting the above error and i made what are the settings required means tool chain integration (compiler,linker,assembler) settings but still getting this. please reply for this
with thanks & regards
srikanth.
