WHAT IS COMMAND LINE IN KEIL? HOW TO PASS PARAMETER VIA IT? FOR COMPILING PROGRAM BY --C99 WHICH PARAMETER HAS TO BE SET
letmegooglethatforyou.com/
This method could also be applied to the other questions in your request.
NO 1. FROM WHERE TO ENTER COMMAND UV4 -b PROJECT1.uvproj?
2. ENTERING FROM RUN COMMAND IN WINDOWS,GENERATE ERROR:
I THINK YOU ARE TRYING TO DO TOO MUCH COMPLICATED STUFF BEFORE YOU KNOW THE BASIC.
I SUGGEST YOU TRY SOMETHING LIKE THIS FIRST www.computerbasicsguide.com/
CAN SOMEONE REPLY TO THIS QUESTION. HOW TO DO IT. I AM BEGINNER WITH 89C51. KINDLY DO NOT REPLY OF YOU DO NOT WANT TO ANSWER MR. ANNE-DREW.ITS NOT LIKE IT WILL GAIN POPULARITY TO YOU
BUT WHAT YOU ARE ASKING HAS NOTHING TO DO WITH 89C51 OR EVEN KEIL - IT IS BASIC PC OPERATING SKILLS!!
Go to your Keil\C51_905\C51\Hlp\ folder, and locate the GS51.chm file; it is the Keil Getting Started User's Guide for 8051 Microcontrollers.
You will also need to study the other tool Manuals:
http://www.keil.com/support/man_c51.htm
In particular, take time to work through the examples in the uVision manual:
http://www.keil.com/support/man/docs/uv4/uv4_examples.htm
Note that tool manuals are not beginner's guides - they assume that the user is already familiar with at least the basics of PC operation, microcontrollers, programming, embedded development, etc.
For basic study, see:
http://www.keil.com/books/
http://www.8052.com//tutorial
www.8052.com/.../187976
People are specifically ignoring you because you have decided to SHOUT here. Fix your keyboard - a new PC keyboard where the caps-lock isn't stuck doesn't cost much.
HERE IS A VERY USEFUL SITE FOR YOU TO VISIT BEFORE DOING ANYTHING ELSE
www.wikihow.com/Turn-Off-Caps-Lock
Its for LM3S8962. How to build with C99?
So why did you say 89C51, then??!
All the ARM tool manuals are here:
http://www.keil.com/support/man_arm.htm
You should start, as the name suggests, with the Primer:
http://www.keil.com/support/man/docs/gsac/
Again, work through the example programs in the uVision manual:
Books to help you:
Earlier I used CCS for LM3S8962. But if now shifted to Keil. So I tried 89C51 with Keil for starter, but at last have to keil for LM
Read this www.cprogramming.com/.../lesson14.html. It says "Command-line arguments are given after the name of a program in command-line operating systems like DOS or Linux, "
But how/where is place for enter the parameters.
At the command line!
Open up a command line console; e.g., select "run ...", type "cmd" and press "ok".
Then type in the command line you require.
Have to never used anything else except a GUI?
That's talking about passing arguments to your program at run time from an OS such as MS-DOS or UNIX/Linux.
Do you have an OS such as MS-DOS or UNIX/Linux on your LM3S8962...?
To pass controls to the tools at build time - see the Documentation for the tools!
Have you studied the specific documentation for the Keil tools yet?
Note that your link didn't work because you put a full-stop ("period") at the end of it. Always leave clear whitespace around URLs - otherwise the "linkification" won't work. The correct link is:
Aparently not! (CCS is a GUI/IDE).
But there is no need to!
As already noted, build-time controls for the tools can be specified via the GUI (uVision or CCS or whatever) - the OP needs to Please read the manual for details...
What's the world coming to?
IMHO, knowing the command line is a fundamental.
I can even get to a command line on my Android phone.
Agreed - and this thread is a perfect example!
