AgsiSetWatchOnMemory( ) in AGSI doesn't work
Hi, now i m working on C251 Debugger , using AGSI interface to realize some Peripheral.
In AgsiEntry function, i set watch on memory, range 0x1000~0x1fff, run() is a callback function when memorys are writed
void run(void)
{ Agsi.Message("run");
} ........ AGSIEXPORT AgsiEntry(DWORD nCode, void *vp)
{ switch (nCode) { case ... case AGSI_INIT: { Agsi.SetWatchOnMemory(0x1000, 0x10ff, run, AGSIREADWRITE); break; } }
then i open proj file and worte a test program which write 0x1000 in loop, compiled and start debug session, but there is no message "run" in command window. It means AgsiSetWatchOnMemory doesn't work.
Anybody please tell me why this happen and how to Solve the problem .
Thank you very much
