I am using the HY mini STM32V eval. board and are trying to set up a simple USART transmission. The board has a UART-to-USB uC so I need to write to USART1. I use RealTerm terminal. I am new to ARM and this is my first ARM. I can't seem to get it to work. It seems that the break and error indicator in RealTerm are flashing sometimes. I do not wish to use the standard library provided (by STM). I will post my code here and if someone has the time to look at it, it would be much appreciated! Any feedback is welcome!
(I saw the tabs got a little off, but should still be readable).
#include "stm32f10x.h" //LED #define LED_1 GPIO_BSRR_BS0 #define LED_2 GPIO_BSRR_BS1 #define LEDPORT GPIOB //GPIO #define GPIO_CR_MODE_RESET 0 #define GPIO_CR_MODE_OUTPUT_2MHZ 2 #define GPIO_CR_MODE_OUTPUT_10MHZ 1 #define GPIO_CR_MODE_OUTPUT_50MHZ 3 #define GPIO_CR_CNF_OUTPUT_PUSHPULL 0 #define GPIO_CR_CNF_OUTPUT_OPENDRAIN 1 #define GPIO_CR_CNF_OUTPUT_AFIO_PUSHPULL 2 #define GPIO_CR_CNF_OUTPUT_AFIO_OPENDRAIN 3 #define GPIO_CR_CNF_INPUT_ANALOG 0 #define GPIO_CR_CNF_INPUT_FLOATING 1 #define GPIO_CR_CNF_INPUT_PULLUPDOWN 2 #define GPIO_setPinModeL(port, pin, mode) port->CRL |= (mode << 4*pin) #define GPIO_setPinModeH(port, pin, mode) port->CRH |= (mode << ((4*pin) - 32)) #define GPIO_setPinCnfL(port, pin, cnf) port->CRL |= (cnf << ((4*pin) + 2)) #define GPIO_setPinCnfH(port, pin, cnf) port->CRH |= (cnf << ((4*pin) - 32 + 2)) #define GPIO_initPort(port) port = 0x0000 //USART #define USARTPORT GPIOA //Delay fucntion void DELAY(int delay) { volatile int dly; for(dly = 0; dly < delay; dly++); } //LED functions void LED_init(void) { RCC->APB2ENR |= RCC_APB2ENR_IOPBEN; //Enable port B clock GPIO_initPort(LEDPORT->CRL); //Have to set CRL to 0x0000 before we can bitwise or to the register. GPIO_setPinModeL(LEDPORT, 0, GPIO_CR_MODE_OUTPUT_2MHZ); GPIO_setPinModeL(LEDPORT, 1, GPIO_CR_MODE_OUTPUT_2MHZ); } void LED1_set(void) { LEDPORT->BSRR = LED_1; } void LED2_set(void) { LEDPORT->BSRR = LED_2; } void LED2_clear(void) { LEDPORT->BRR = LED_2; } //USART funtions void USART1_send_byte(int byte) { while( !(USART1->SR & USART_SR_TXE) ); USART1->DR = byte; } int USART1_get_byte(void) { while( (USART1->SR & USART_SR_RXNE) != 0 ); return ( (int) (USART1->DR & 0x000000FF) ); } void USART1_init(void) { RCC->APB2ENR |= RCC_APB2ENR_USART1EN; //Enable USART clock RCC->APB2ENR |= RCC_APB2ENR_IOPAEN; RCC->APB2ENR |= RCC_APB2ENR_AFIOEN; //NULL registers USART1->CR1 = 0x0000; USART1->CR2 = 0x0000; USART1->CR3 = 0x0000; USART1->BRR = 0x0000; //Tx - PA9 GPIO_setPinModeH(USARTPORT, 9, GPIO_CR_MODE_OUTPUT_50MHZ); GPIO_setPinCnfH(USARTPORT, 9, GPIO_CR_CNF_OUTPUT_AFIO_PUSHPULL); USART1->CR1 |= USART_CR1_UE; USART1->BRR = ( (1 << 0) | (0x00000034 << 4) ); // 8MHz system clock and 9600 baud rate. USART1->CR1 |= USART_CR1_TE; //Rx //GPIO_setPinModeH(USARTPORT, 10, GPIO_CR_MODE_OUTPUT_50MHZ); //GPIO_setPinCnfH(USARTPORT, 10, GPIO_CR_CNF_INPUT_FLOATING); //USART1->CR1 |= USART_CR1_RE; } /********* MAIN *********/ int main(void) { LED_init(); USART1_init(); //USART1_init2(); USART1->DR = 0x000000AA; LED1_set(); while(1) { USART1_send_byte(0x000000BB); LED2_set(); DELAY(5000000); LED2_clear(); DELAY(5000000); } }
I rewrote and simplified the program. Still not able to see any data on the receiving end. I have used RealTerm and Terminal v1.9. I ran an example program and was able to receive data so it is not damaged in any way. There must be something I am missing. Here is the new code:
#include "stm32f10x.h" int main(void) { //Inits. RCC->APB2ENR |= (RCC_APB2ENR_IOPAEN | RCC_APB2ENR_USART1EN | RCC_APB2ENR_AFIOEN); GPIOA->CRH |= (GPIO_CRH_CNF9_1 | GPIO_CRH_MODE9_1 | GPIO_CRH_MODE9_0); USART1->CR2 &= (~USART_CR2_CPOL | ~USART_CR2_CPHA | ~USART_CR2_CLKEN | ~USART_CR2_LBCL | ~USART_CR2_STOP); USART1->CR1 &= (~USART_CR1_M | ~USART_CR1_PCE | ~USART_CR1_PS | ~USART_CR1_TE | ~USART_CR1_RE); USART1->CR1 |= USART_CR1_TE; USART1->CR3 &= (~USART_CR3_CTSE | ~USART_CR3_RTSE); USART1->BRR = ( (0x0034 << 4) | (0x0001) ); //9600 @8MHz USART1->CR1 |= USART_CR1_UE; while(1) { USART1->DR = (uint8_t) 0xAA; while(! (USART1->CR1 & USART_SR_TC) ); //while(! (USART1->CR1 & USART_SR_TXE) ); } }
