C++ error: Class with constructor: Argument not checked
to disable and re-enable interrupts in a safe way, I wrote the following class:
class DisableIntsShortly {
public:
  __forceinline DisableIntsShortly(){ __disable_irq(); }
  __forceinline ~DisableIntsShortly() {__enable_irq(); }
Thus then I should be able to protect my code with non-atomic access to interrupt variables like this:
    DisableIntsShortly DI();
    ... do some things where interrupt needs to be disabled.
Unfortunately this does not work - the DI is not used inside this block, therefore the optimizer seems to think that it is useless and just kills it.
To come around this, I tried it like this:
public:
  __forceinline DisableIntsShortly( int i){ __disable_irq(); i=i; }
Then it works if I write this (at least in optimization level 1):
    DisableIntsShortly DI( 0);
Just one severe problem: If I write "DisableIntsShortly DI();" (omit the 0), then NO ERROR appears (and again the optimizer decides to just kill it - without any warning or error - could some people at Keil please solve this? Here definitely an error should appear.
(And further the optimizer should not remove class instances with custructor and/or destructor functions).
  • There are always issues with compilers doing global optimization.
    What happens if you add a global, volatile, variable and have your constructor do var++ to force a volatile memory access? The advantage with that is that you would also be able to trace the number of critical sections your program visits.
