32k NDATA
Hi all ,
Using Uvision4 with XE167
Memory model large
My problem is the 16k NDATA limit, although DPP0 is unused.
I use
 DPP1 NCONST
 DPP2 NDATA
 DPP3 SYSTEM
and that is not alterable for legacy reason.
I set in startup-file
 DPP0 = DPP2 + 1
added a section NDATA1 describing this memory
CLASSES ( NCODE (010000H - 01FFFFH),
          NDATA (290000H - 293FFFH),
          NDATA0(290000H - 293FFFH),
          NDATA1(294000H - 297FFFH),
put in c-file:
 #pragma RENAMECLASS (NDATA = NDATA1)
 #pragma NOINIT
 static int_t near data1;
The variable is located in the memory section I wanted it to be,
DPP0 has the value I wanted it to have,
but the programm running seems to use DPP2 for accessing data1, so
functionality is not given.
In assembler you can specify
ASSERT DPP0 : NDATA1
I didn't test it but I assume that will work.
My question:
Is there a possibility to tell the compiler/linker that DPP0 has to be used for data1?
Thanks in advance
Jürgen
