Extracting the data from adc data register in lpc2138 ?
Hi I how to extract the data for multiple input to adc port in lpc2138 .
Here is the code for initialization of the adc and tell me how to extract the data for both the adc
void adc_ini(void)
                PINSEL1 = 0X05000000; //pin 13 p0.28 and p0.29 adc 0 channel 1 and 2
                PCONP |=  0X00001000;   //select adc 0 bit 12
                AD0CR &=  0X00000000;
                AD0CR |=  0X00200206; // WITH PCLK 12/(2+1)=4MHZ ADC0 CHANNEL 1 and 2 PIN 13 and 14
                AD0INTEN &= 0x00000000; //Completion of a conversion on ADC channel 0 will not generate an interrupt.
void adc_data(void)
                    AD0CR  |= 0x01000000;              /* Start A/D Conversion         */
                    while((AD0DR & 0x80000000)==0); //until bit 31 is high (DONE)
                    val = AD0DR; //read a/d data register
                    adc_val = ((val >> 6) & 0x3FF);    // Extract AD result
How to modify for extracting the data from both the data register ?
Thanks in advance
