Hello. I would like to integrate third-party debugger "emulator that supports JTAG debugging for ARM7 and ARM9 devices" to keil uvision, so I could flash LPC2214 using that debugger. Our university has a bunch of them, so they found it easier and more educative to integrate these debuggers then buying a lot of branded jtag debuggers. Could you please give a cue what i am to do. I guess, the point is to write a driver or modify the existed third-party driver, isn't it?
Correct.
Have you checked first whether this "third-party debugger" already has Keil support?
The interface details are here: http://www.keil.com/appnotes/list/uvision.htm
Yes, and i did not find any mentions. It's "jem-arm" from phyton.
Okay, let's suppose that I have written a driver for that third-party debugger. What's next step?
Just open tools.ini file in the Keil folder and add this debugger to the list of existing ones. It's an ordinary text file, so when you open it in the notepad, it will be clear how to do it. The hardest part will be writing your own debugger dll, though.
- Dejan
Okay guys, I've had the other work to do, now back to this problem: I've found out the JEM-ARM Debugger installs as "USB Serial Converter" and "USB Serial Port (COM10)". Information about drivers from the Windows Device Manager is below: USB Serial Converter Driver files: C:\Windows\system32\drivers\ftdibus.sys C:\Windows\system32\ftbusui.dll C:\Windows\system32\ftd2xx.dll C:\Windows\system32\FTLang.dll C:\Windows\system32\ftd2xx.dll
USB Serial Port (COM10) Driver files: C:\Windows\system32\drivers\ftser2k.sys C:\Windows\system32\DRIVERS\serenum.sys C:\Windows\system32\ftcserco.dll C:\Windows\system32\ftserui2.dll
Adding path to one of the dlls to the TOOLS.ini leads to the following message when I choose the device: Error: Cannot load driver <path to the dll here> Possible reasons: Driver DLL could not be found in the specified path Driver DLL requires additional DLL's which are not installed Required Hardware Drivers are not installed
I suppose the 2nd reason, so how do I mention additional dlls? or am I completely wrong speaking of the driver files above and still need to write the driver? Thanks for your time.
Additional info: this debugger is based on the FTDI FT232RL chip and Atmega8L.
