LPC2368 (ARM7) External Interrupt concept
Dear all,
We are using the LPC2368 processor for our application. For this, need to configure the external interrupt (EINT1). For configure the interrupt, we wrote the code as below shown,
__irq void isr_handler_eint1(void) //Interrupt function
VICIntEnClr = (1 << 15);
InterruptCounter++; //For checking, whether the interrupt occurs or not.
EXTINT |= 0x02;
VICIntEnable = (1 << 15);
VICVectAddr = 0;
void inpt_init1()
PINSEL4 |= 0x00400000; //select the pin for the external interrupts_0
EXTMODE |= 0x02; //INT 1 is configure as edge sensitive mode
VICVectAddr15 = (unsigned int) &isr_handler_eint1;
EXTPOLAR = 0x00; //INT 1 is falling edge, default
EXTINT |= 0x02; // in edge sensitive mode, if this bit is set, the interrupt occurs while the selected edge is occurs in this pin
VICIntEnable |= 0x00008000; //enable the vector interrupt
In application, we are continuously checking the InterruptCounter. But the interrupt counter is not incrementing. It was showing always '0'. But, we are providing the interrupt pulse to the EINT1 pin continuously.
ETM interface also disable. We didn't understood the problem where it happening. Our code was correct or not?
Please give us a solution to solve this issue.
Regards,
Vijay.
