hid composite
I have lock dead lock problem in PC windows xp service pack III (tested also in windows 7)
I already use hid generic single hid with success.
Now I am trying to use LPC17xx composite Hid
Hid generic + hid generic
I use 2 interfaces
Interface 0 for Hid 0
use endpoint 1 output 0x81 input
(same endpoint)
Interface 1 for Hid 1
use endpoint 0x84 input
I use logical endpoint 4 because from table 185-fixed endpoint configuration in lpc17xx manual, that endpoint is one interrupt endpoint.
I already modify in Hid example NUM_INTERFACES 1 <---2
and modify in usb_core.c with 2 case the subbranches
case HID_HID_DESCRIPTOR_TYPE
case HID_HID_REPORT_DESCRIPTOR_TYPE ( see later in post)
Enumeration seems successfull and endpoint 1 is working
but when in PC I open second interfaces
_mi01
from PC is possible to open stream but readfile lock in pc like that endpoint 4 is not working
At the end of post output of usbview
PC program has been modified from keil example and we already work successfully with single hid.
\\?\hid#vid_17xx&pid_062a&mi_00#7&104386fe&.......
\\?\hid#vid_17xx&pid_062a&mi_01#7&341ac4c0&.......
Descriptor used are:
#define HID_DESC_OFFSET 0x0012
#define HID2_DESC_OFFSET HID_DESC_OFFSET+HID_DESC_SIZE+USB_ENDPOINT_DESC_SIZE*2
#define HID_INPUT_REPORT_BYTES USB_PACKET_SIZE /* size of report in Bytes */
#define HID_OUTPUT_REPORT_BYTES USB_PACKET_SIZE /* size of report in Bytes */
#define USB_PACKET_SIZE 8
#define USB_MAX_PACKET0 8
From Usbview
Device Descriptor:
bcdUSB: 0x0110
bDeviceClass: 0x00
bDeviceSubClass: 0x00
bDeviceProtocol: 0x00
bMaxPacketSize0: 0x08 (8)
idVendor: 0x1722
idProduct: 0x062A
bcdDevice: 0x0100
iManufacturer: 0x01
0x0409: "Elad "
iProduct: 0x02
0x0409: "Composite TEST"
iSerialNumber: 0x00
bNumConfigurations: 0x01
ConnectionStatus: DeviceConnected
Current Config Value: 0x01
Device Bus Speed: Full
Device Address: 0x01
Open Pipes: 3
Endpoint Descriptor:
bEndpointAddress: 0x81 IN
Transfer Type: Interrupt
wMaxPacketSize: 0x0008 (8)
bInterval: 0x20
bEndpointAddress: 0x01 OUT
bInterval: 0x20
bEndpointAddress: 0x84 IN
bInterval: 0x0A
Configuration Descriptor:
wTotalLength: 0x0042
bNumInterfaces: 0x02
bConfigurationValue: 0x01
iConfiguration: 0x00
bmAttributes: 0xE0 (Bus Powered Self Powered Remote Wakeup)
MaxPower: 0x32 (100 Ma)
Interface Descriptor:
bInterfaceNumber: 0x00
bAlternateSetting: 0x00
bNumEndpoints: 0x02
bInterfaceClass: 0x03 (HID)
bInterfaceSubClass: 0x00
bInterfaceProtocol: 0x00
iInterface: 0x00
HID Descriptor:
bcdHID: 0x0111
bCountryCode: 0x00
bNumDescriptors: 0x01
bDescriptorType: 0x22
wDescriptorLength: 0x0019
bInterval: 0x20
bInterval: 0x20
bInterfaceNumber: 0x01
bNumEndpoints: 0x01
iInterface: 0x00
HID Descriptor:
bcdHID: 0x0111
bCountryCode: 0x00
bInterval: 0x0A
  • Sound like you are working on this HID example, aren't you?
    C:\Keil\ARM\Boards\Keil\MCB1700\USBHID
    Maybe, your firmware doesn't put any packet to the EP4.
    In this USBHID example, (1) the first packet is put to EP1 at USB_Configure_Event(), which is called at Set_Configuration request.
    usbuser.c
     *  USB Set Configuration Event Callback
     *   Called automatically on USB Set Configuration Request
    #if USB_CONFIGURE_EVENT
    void USB_Configure_Event (void) {
      if (USB_Configuration) {                   /* Check if USB is configured */
        GetInReport();
        USB_WriteEP(HID_EP_IN, &InReport, sizeof(InReport));    // <--- (1)
    #endif
    The second and latter packets for EP1 are provided (2) in USB_EndPoint1()
    usbuser.c
     *  USB Endpoint 1 Event Callback
     *   Called automatically on USB Endpoint 1 Event
     *    Parameter:       event
    void USB_EndPoint1 (U32 event) {
      switch (event) {
        case USB_EVT_IN:
          GetInReport();
          USB_WriteEP(HID_EP_IN, &InReport, sizeof(InReport));    // <--- (2)
          break;
    If you would like to make EP4 work as EP1, you need to write similar code for EP4.
    To make USB_EndPoint4() work, this macro should be touched.
    usbcfg_LPC17xx.h
    #define USB_EP_EVENT        0x0003     // <--- 0x0013
    Tsuneo
  • Yes
    I made point 1 and 3 (2 already done before) and endpoint 4 was working.
    Thank you very much for your help.
    Grattoni Enore
