Check heap & stack size during debug
How can I check heap & stack size during debugging.
I am using LPC1317 with Keil 4.54.0.0
  • To check heap usage, as far as I can tell there are no facilities in the Keil tool chain to do this. I needed to do this recently for a project, so I wrote some test code that uses the following:
    __heapstats()
    __heapvalid()
    See stdlib.h for their definition. Use of these functions requires the standard C library (not MicroLIB).
