where can i get procedure for 2048 encryption bits?
Do you think 2048 bit encryption is something Keil develops and sells?
Don't you think Google is a way better source for locating source code for different encryption algorithms? But maybe, just maybe you should figure out what encryption algorithm you want. I would have to assume RSA - but assumptions are bad. You really should know what algorithm you want to use.
